1989 Sable No spark
1989 ALL OTHER MAKES ALL OTHER MODELS
DOITINBACK
Not sure what's going on with this one, it runs when it wants, then quits suddenly. I replaced the cap, rotor, coil, and coil wire. After that it seemed to be running fine. It suddenly quit running, and is not getting any spark. It won't fire when I shoot a little starting fluid in the air cleaner, and I did check the voltage at the coil and it says 12.3vdc. Any ideas?
May 5, 2007 at 10:18 AM
DOITINBACK
[quote:a778036792="justanold"]HELLO! Before you do anything else..replace the ignition module. please get back to me with results good or bad. you may well end up inside the distributor. 8) 8) 8)[/quote:a778036792]
Hello, I did replace the ignition module and the car started right up. Unfortunately, it was driven about 1.5 miles and everything went out. No power at all.
I haven't had time to check into this situation yet, any idea where to start?
May 6, 2007 at 3:14 AM
