HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
All Other Makes
All Other Models
Body
Door
Symptoms
Open
SPONSORED LINKS
1989 Questions for all other cars
WINNIE99
MEMBER
1989 ALL OTHER MAKES ALL OTHER MODELS
Electrical problem
1989 Questions for all other cars 6 cyl Front Wheel Drive Manual
THE CENTRAL LOCKINGON THE PASSAGER BACK DOOR ON RENAULT MEGANE IS NOT WORKING AND THE DOOR CAN NOT BE OPENED
Monday, June 23rd, 2008 AT 2:12 AM
KHLOW2008
MECHANIC
Hi winnie99,
If you cannot manually unlock to open the door, the central lock actuator is jammed.
Door panel needs to be removed to get acess to it and with door closed, it is not going to be easy.
SPONSORED LINKS
Saturday, July 5th, 2008 AT 11:45 PM
Please
login
or
register
to post a reply.
Related Door Open Content
2005 Pt Cruiser
My Back Doors Have To Be Unlocked From The Front Before They Will Open From The Inside. Is That How They Are Suppose To Be Or Should They...
Asked by
melbox42141
1 ANSWER
2005
3-wire 2 Relays Added But Not Working For Remote Doors
I Installed The 2 Relays As Described For The 3-wire Setup On A Positive Door Lock System Required For My 1990 Cutlas Ciera. Problem Is When...
Asked by
Fwayz
1994 Cevy Astro Van
The Door Panel On The Driver's Side Is Coming Loose. Everytime You Open The Door It Sticks And Pulls Apart More. How Can I Fix It?
Asked by
Deanna Jenkins
1 ANSWER
1994
1999 Astro Van Back Door
The Back Door Of The Van Has Electric Locks. When I Push The Button To Open The Upper Door ( The Van Has The Split Lower Doors And The Upper...
Asked by
bob1950music
1999
How Can I Realign Sliding Door On A Ldv Maxus 2006...
I Have Got A Used Roller That Goes In The Bottom Rail And Hinge That Worked Ok Off The Van It Came Off Of. Now Fitted On My Van The Door...
Asked by
THE TYRE TECHNICIAN
2006
VIEW MORE
SPONSORED LINKS
Fix a Door That Will Not Close
Door Panel Removal
Door Lock Replacement
Online car repair manuals
