1989 PROBE GT TURBO CLUTCH!!!!!
1989 ALL OTHER MAKES ALL OTHER MODELS
SPITFIREMIKE
yes i have a 89 probe gt turbo and just recently i was driving it and i noticed it was starting to slip.I could press the gass down and the rpms would go up but wouldnt take off like it should.I smelt what i thought was the clutch burning because it was almost like a burn out smell..idk what it is but now if i put it into 1st or any gear i can press the gass and it wont go nowhere?? i can even let the clutch out in 1st and it wont die like it should it stays idled?? is this the clutch or what i could use some help on how to fix and what to buy??????
Jan 13, 2007 at 8:53 AM
SERVICE WRITER
  • 9,123 POSTS
Mike, thanks for donating, you get priority because of it.
Its sounds like it's clutch time.
You need need a new clutch kit, that should have the new disc, pressure plate throw out bearing and pilot bearing.
Jan 13, 2007 at 9:00 AM
SPITFIREMIKE
well.. im on kinda a budget i had a feeling i was right.thanks for such a quick reply.ya i dont want to buy a compleate clutch kit so what do i need,the plate?? idk that i need a whole kit?? its only 50 for the plate but 250 for kit??
Jan 13, 2007 at 9:03 AM
SERVICE WRITER
  • 9,123 POSTS
I can appreciate the budget side. You may spend a lot of time replacing this, is it worth doing twice? and maybe have to replace the new part if it gets damaged?
What size motor? 2.2?
Jan 13, 2007 at 9:21 AM
SPITFIREMIKE
its a 2.2l turbo fwd, well i think its just worn??lol well if it comes to that ill get a new kit.
Jan 13, 2007 at 9:24 AM
SERVICE WRITER
  • 9,123 POSTS
I mean 118
Jan 13, 2007 at 9:25 AM
