1989 Probe Break pedal drops
1989 ALL OTHER MAKES ALL OTHER MODELS
EDDIE1
1989 probe lx/2.2l w/60000mls I get a normal break pedal coming to a stop, when I slightly release to move up a little then reapply breaks, pedal drops about an inch then grabs. This will happen cosistently until pedal reaches floor.
Dec 1, 2006 at 12:20 PM
CATCH_15
  • 250 POSTS
The first thing to do is check the brake fluid level. Check for leaks etc.
Dec 1, 2006 at 12:27 PM
EDDIE1
There are no leaks and the fluid level is a little overfull. I also maintain a nice firm pedal when depressing on pedal.
Dec 1, 2006 at 12:32 PM
CATCH_15
  • 250 POSTS
So if you try to pump the brakes, do you build up pressure or lose it?
Dec 1, 2006 at 2:19 PM
EDDIE1
Had to go and check. If I completely let the pedal return, I can pump with a normal, firm pedal even in park. Depending on how far I let the pedal raise is when I am getting the drop. While driving I apply breaks to slow down(normal pedal) then reapply without letting pedal come all the way up(normal) come to a stop(normal) let the pedal come up to where pads release and car inches up then reapply(pedal drops about 3/4inch then grabs)
Dec 1, 2006 at 2:59 PM
1BIGG1
  • 61 POSTS
you may wanna try bleeding your brakes, as long as you know what your doing. probe power all the way, i also own a 1989 probe gl 2.2 5spd.
Dec 3, 2006 at 8:18 PM
