1988 Questions for all other cars Firing order
1988 ALL OTHER MAKES ALL OTHER MODELS
SANDYPOND
Engine Mechanical problem
1988 Questions for all other cars V8 Two Wheel Drive
I installed a new sbc hei distributor (1 unit w/coil and elec ign.) for 350 chevy 260. I am pretty sure firing order was correct, but now realize rotor may have been in wrong position. When I tried to start. engine went "clunk" and smoke came from battery terminal like engine is locked up. Did engine lock up? What should I do?
note:The engine is on a Mercruiser out drive.
Bernie
T
Jul 28, 2008 at 12:36 AM
KHLOW2008
  • 41,814 POSTS
Hi Bernie,
Manually turn the engine and see if it is seized. Are you sure the distributor fits?
Valve timing correct?
Aug 1, 2008 at 9:39 AM
