1987 Questions for all other cars No brake fluid @ wheel
1987 ALL OTHER MAKES ALL OTHER MODELS
120,200 MILES • 4 CYL • 2WD • MANUAL
HUGO THE YUGO
My Yugo has sat for 3 years as a result brakes are rotten. I replaced both front calipers. The left works as expected the right does not work. I removed the brake line and pumped the petal and find very little brake fluid comes out. I figure that both front brakes work on the same part of the master cylinder, since the left works I am stumped. Before I started I could get fluid out of the bleader screw on both sides. I have been careful not to get dirt in the line and have inserted a wire up into the line to check for trash. Is the master cylinder the next item to replace??
Dec 20, 2009 at 7:26 AM
  • 31,937 POSTS
Hi there, i would be replacing the brake hoses and checking the pressure at the master cylinder, start here.
mark (mhpautos)
Dec 20, 2009 at 8:21 AM
