1987 Mercedes Benz 420SEL
1987 ALL OTHER MAKES ALL OTHER MODELS
MWHIT1230
Passenger side headlight goes blank when on dim. New bulbs do not help. Fuses have been checked. What could be the cause?
Jan 17, 2007 at 12:47 PM
MATHIASO
  • 1,209 POSTS
Formerly one of the most basic circuits in the vehicle, the headlights have automatic dimming light-sensing switch to automatically turn them on, and auxiliary driving lights integrated into them.Keep in mind that these items have their own controllers and relays that operate them.Always turn to your DMM and wiring diagrams to isolate problems.
The dimmer switch in older application is connected in series between the switch and the headlamps.When curent is turned on the dimmer switch directs the curent to the selected bulb.
checking that dimmer swicth may help you find the answer of your question.
Jan 17, 2007 at 3:08 PM
MWHIT1230
I would believe that could work, but this vehicle has no automatic headlight dimmer. It's done with the signal lever. It must be something else. What's unusual is that it's only the passenger side that goes out.
[quote:6e5484e5f9="mathiaso"]Formerly one of the most basic circuits in the vehicle, the headlights have automatic dimming light-sensing switch to automatically turn them on, and auxiliary driving lights integrated into them.Keep in mind that these items have their own controllers and relays that operate them.Always turn to your DMM and wiring diagrams to isolate problems.
checking that dimmer swicth may help you find the answer of your question.[/quote:6e5484e5f9]
Jan 18, 2007 at 3:49 AM
MATHIASO
  • 1,209 POSTS
(the signal lever ) and the headlamps.When curent is turned on the dimmer switch directs the curent to the selected bulb.
you need a wiring diagram and a DMM.
Jan 18, 2007 at 2:57 PM
