1977 Questions for all other cars V8 Two Wheel Drive Automatic
I can't get good enough spark at plugs to fire. The truck would not start one day. It was found that the pick-up coil in the dist. was bad and replaced. It was sending signal fine after that and we got a small amount of spark at coile wire, but not enough to fire. The ign coil and ign. module were both replaced and still have the same problem. It sparks really good with key on and off but when in crank mode, very weak. We have good power at pos term of coil, we have a good signal to neg terminal as it flashes with test light as we crank. We have ignition power to module. There is a white wire coming off module that was previously cut and leads nowhere but the truck has run fine this way. We did put a 3.5ohm internal resisted coil on to replace the 2.4 ohm coil that was on before. The problem was that the non-internal res. coil had no ballast resistor in the system. Again, the truck ran fine this way but thought we would eliminate this as a possible problem. The spark at the coil wire can't jump but about .0020 and hasn't enough energy to make it to the plugs. Grounds are good. Powers are good. We have tried 3 different igntion modules with same results. What is going on?
Oct 22, 2008 at 2:13 PM
