1971 Questions for all other cars car won't move
1971 ALL OTHER MAKES ALL OTHER MODELS
DANTHEMAN1990
Transmission problem
1971 Questions for all other cars Two Wheel Drive Manual
hi there , i have an old classic car , vanden plas princess 1971 1300 , car drove fine until recently , car will start but will not move forwards , i have changed drive shaft couplings as i found these to be very worn , but the problem remains , would appreciate any help thankyou
Apr 30, 2009 at 8:35 AM
KHLOW2008
  • 41,814 POSTS
Hi dantheman1990,
When engaging gears and releasing the clutch, any driveshaft fault should produce grinding noise. If no noise are present, the problem should be with the clutch, they could be worn.
Do you have clutch pedal pressure and is the clutch pedal very stiff?
May 5, 2009 at 6:48 AM
