1971 Nova Instrument Cluster
1971 ALL OTHER MAKES ALL OTHER MODELS
ZAFRA
I cannot seem to get the Instrument Cluster and plastic console out it seems to be getting stopped by the light switch does anyone have any idea how to remove it?
May 5, 2007 at 9:33 AM
BURRBRIAN
  • 158 POSTS
On older chevy's, the kind you can work on yourself in the drive at home- it's pretty simple to take out the switch, actually. To remove the shaft that holds the knob on you have to find a little spring loaded button on the switch unit itself. Reach up behind the dash and find the boxy switch and feel around on it- I think it is on the column side of the switch for the button, press it in and pull knob out- it should come all the way out of the switch and clear the way to remove the dash faceplate. Can be a pain the first time or so but once you get it it's really easy after that. good luck. :twisted: Oh, it is also held on with a nut on a threaded shaft that sticks through but I'm sure you have seen that part. :mrgreen:
May 7, 2007 at 1:35 PM
