02 Passat
CSTAYTON
  • 2002 ALL OTHER MAKES ALL OTHER MODELS
I just bought an 02 Passat and the check engine light came on. I was talking with some friends about it and they think cause I used a cheap gas station to fill up, there may be water in my tank. My dad said to use a can of HEAT and try that first. Where do I get a can of heat and is that worth it? Should I just take it to the dealer?
Tuesday, May 2nd, 2006 AT 4:17 PM
SYNCRAIT
  • 235 POSTS
You can get a can of heat at most any gas station which will remove some of the moisture from the tank its only a few dollars so sure its worth a try
Friday, May 5th, 2006 AT 7:34 PM
Related Check Engine Light Content
Is it Safe to Drive Check Engine Light?
VIDEO
