My 02 Grand Prix has issues. It starts and idles fine, runs perfect up to 2200 or so RPM , At full throttle the engine wont run past about 3500 rpm. no load. when driving, usable power is limited to about 2200 rpm and below. transmission shifts fine and on flat ground it can be driven to highway speeds but will only pull up a hill about 20 mph since if you let it downshift you dont have the revs to back it up. I replaced the fuel filter, and checked the fuel pressure on the rail @ 50 psi even while at WOT hovering around 3000 rpm. I have also checked the EGR valve, it was clean and moved freely. ECM shows no codes stored and no check engine light comes on. Anyone got any suggestions?
Feb 22, 2007 at 6:52 AM
