Does a used replacement ignition cylinder, key with transponder and ECM need to be programmed
160,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
SNAPON6274
Lost all keys to car. So have used ignition cylinder, key with transponder and ECM. When i install this will it fix my car anything special needed to do to erase or program.
Feb 24, 2020 at 10:01 PM
Good morning,
The ECM will need to be programmed along with the key.
I would have just left the old ECM installed and replace the key and switch. Then you could have had a locksmith come to you and program the key to the car.
Feb 24, 2020 at 10:49 PM
SNAPON6274
Can't afford locksmith.
Feb 24, 2020 at 11:10 PM
It will be cheaper than flashing your ECM to your VIN and programming the key.
Feb 25, 2020 at 2:28 AM
