All Gears Gone?
145,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
PRD
No forewarning. No problems or clues at all prior. It was running great. All fluids checked and good before I left. Driving down the highway, 75mph, approximately 250 miles into the 360 mile trip I was taking & all of a sudden it was like it had seamlessly slipped into neutral. I tried moving the gearshift into neutral & back into drive & nothing. Coasted to the side of the road, tried all gears multiple times & none would catch. Rechecked trans. fluid - still good. Checked shift rod/lever, it looked fine. Had to be towed the remaining 110 miles. Took transmission pan off replaced filters & fluid. No sludge or metal shavings in pan. The old flat filter had a crack in one side. Thought problem would be fixed then, but no. From the time I was on the side of the road I had noticed a low whirring sound it had never made before, specifically when I was starting it, moving gear shift or accelerating. I finally figured out the whirring noise was coming from inside the housing where the flexplate is. Also when I turn vehicle off you can distinctly hear the whirring winding down. I haven't gotten inside that housing to look yet. Seems a little intimidating of a job for a novice like myself. But I will do if necessary. From what I understand though, if there was a problem with the flexplate itself, or it's connection to the torque converter or drive shaft, there would be a whole lot more noise,(& big problems), going on. Do you think it's more likely to be the pump or the solenoid pack or maybe something like the speed sensor,(which I think will be my next attempt unless someone gives me a reason not to), or do you think it's something else entirely? Oh, also I did try doing a hard reset on the whole electrical system, to no avail...
Nov 10, 2025 at 10:06 AM
  • 55,594 POSTS
Get description of the problem, and yes it can be the flex plate has let go it will make a little noise as it is cracked around the crankshaft mounting flange which is wear they break, either way the transmission will probably needs to come out because if the flex plate is okay the front pump is bad or the torque converter has come apart. You might want to try running the codes to see if any are stored, this might help us pin point the problem more easily. These guides can help us.
https://www.2carpros.com/articles/how-to-remove-an-automatic-transmission-rwd
and
Please upload a short video in your response of the problem, so I can see what's going on :)
Nov 11, 2025 at 2:42 AM
