All dashboard lights came on and will not turn off
35,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
JOHN UREñA
I jumped my cars battery because it wasn't being driven and the battery died. After jumping the battery, all the dashboard warning lights came on and have not gone away since. It's been a month and over 100 miles driven since then. I tried disconnecting the battery for 15 minutes, tried removing the ECU fuse and replacing it and i got nothing... please help
Feb 25, 2020 at 5:39 AM
  • 110,248 POSTS
When you say all the lights, are you referring to the check engine, battery, brake, ABS, and everything? When you jump started it, by chance did anything short? Is the battery now staying charged? Have you tried having it scanned to see if there is an issue with any of the multiplex integrated control systems?
Feb 25, 2020 at 8:27 AM
