Alignment question?
175,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MADKTD
I had my alignment checked one mechanic said it's good another said it needs fixed how bad is it?
Front driver side. Camber 0.9° Caster 2.6° Toe -0.53°
Front passenger side Camber 0.7° Caster 3.2° Toe 0.27°
Rear driver side Camber 0.2° Toe 0.34°
Rear passenger side Camber -0.1 Toe -0.25
Thrust angle 0.29
This vehicle has been in a minor front-end collision in the past.
Jan 16, 2024 at 2:11 AM
  • 55,721 POSTS
How does the car drive and how are the tires wearing? This is an indication of how bad the alignment is. These specs don't seem too bad to me. Here are what the book specs are. Check out the images (below). Let us know if you need anything else.
Jan 16, 2024 at 3:08 AM
MADKTD
Car drives good, no weird vibrations or anything, Tire ware looks uniform. Thanks for your help.
Jan 16, 2024 at 4:31 AM
  • 55,721 POSTS
You are welcome, please use 2CarPros anytime we are here to help.
Jan 17, 2024 at 1:30 AM
