alignment specifications needed (toe, camber, caster)?
240,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
YAZIDAN
  • 141 POSTS
I would like to know alignment specifications (toe, camber, caster) for my car. Also, I would like to know are camber and caster adjustable for front wheels. And are toe and camber are adjustable for rear wheels? also, i would like to know the track width front and rear.
Thank you
Mar 26, 2024 at 3:34 AM
  • 55,694 POSTS
Sure, here are the alignment specifications for your 2004 Toyota Corolla. Check out the images (below). Let us know if you need anything else.
Mar 26, 2024 at 6:31 AM
YAZIDAN
  • 141 POSTS
Yes please. Also, I would like to know the track width front and rear.
Mar 26, 2024 at 7:50 AM
  • 55,694 POSTS
Can you please explain, track front to rear?
Mar 27, 2024 at 2:05 AM
YAZIDAN
  • 141 POSTS
I need to know the distance between the rear wheels and the distance between the front wheels. they call those track width of the front and track width of the back.
Mar 27, 2024 at 3:09 AM
  • 55,694 POSTS
The wheelbase for the 2004 Toyota Corolla is 102.4 inches.
Mar 28, 2024 at 1:39 AM
YAZIDAN
  • 141 POSTS
Sir,
What I need is shown in the picture. it says "track" for the front two wheels and the rear two wheels.
Thank you
Mar 28, 2024 at 12:43 PM
  • 55,694 POSTS
Sorry, I never had anyone ask this question before. I couldn't find the exact front and rear track measurements in the sources I accessed.
Mar 29, 2024 at 3:28 AM
