Front end wheel alignment specs?
5,700 MILES
BRICKBRICKVX
Out of specification. Front end wheel alignment specs please?
Nov 29, 2022 at 4:56 AM
  • 55,710 POSTS
Here are the specs on wheel alignment for the front and rear. I have included the instructions for the wheel alignment as well in the diagrams below.
Caster angle: 5 ° 11 ’±30 ’
(Maximum difference between the right and left side: 0 ° 30 ’)
FRONT
Camber angle:
-0 ° 18 ’±30 ’
REAR
Camber angle:
-1 ° 12 ’±45 ’
(Maximum difference between the right and left side: 0 ° 45 ’)
Rear total toe-in:
2.1+2-1 mm (0.08+0.08-0.04 in)
Front total toe-in:
0 ± 2 mm (0.00 ± 0.08 in)
Turning angle:
Inward:
38 ° 53 ’±2 °
Outward (reference):
31 ° 32 ’
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Nov 29, 2022 at 8:18 AM
