Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-350
Tires
Alignment
Alignment specs needed
1985 FORD F-350
400,000 MILES • 6.9L • V8 • 2WD • MANUAL
BRADLEY KENNEDY
MEMBER
Can someone give the alignment specs for the truck listed above?
Mar 6, 2020 at 10:09 AM
Experienced Mechanic
I attached the specs for camber and caster. Then the entire process. Let us know if you need more info. Thanks
Images (Click to enlarge)
Mar 6, 2020 at 10:18 AM
BRADLEY KENNEDY
MEMBER
Thank you!! Was exactly what I've been looking for.
Mar 6, 2020 at 10:30 AM
You are welcome. Come back anytime you need other info. Thanks for using 2CarPros.
Mar 7, 2020 at 9:07 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
