1969 Alfa Romeo Spider
RONADO
Brakes problem
1969 Alfa Romeo Spider 4 cyl Two Wheel Drive Manual
Brake pedal is spongy, went to bleed brakes and no fluid came out of the bleed ports
Feb 3, 2009 at 10:41 AM
DR LOOT
  • 2,311 POSTS
I come across this problem quite frequently on older cars, the road grime builds up in the bleeder, you have to remove the bleeder completely, and make sure it is clean, if it is clean and you still have fluid, you must have a bad master cylinder, but I doubt it.
Feb 28, 2009 at 4:22 PM
