Smokey Exhaust
ALFA ROMEO
GINARD67
Alfa Romeo 147 1.6 Spark 58093 mil. 1995. Dear sirs. My car, when stationary (the engine is still on) releases quite a lot of smoke, this has gradually got worse. The pipe is quite dark in the inside. Could you tell me what you think it could be?
Nov 26, 2007 at 7:57 PM
  • 75,988 POSTS
Ho Ho Ho Merry Christmas
Yes I can help but what kind of rainbow color is coming out from the tailpipe-Is it black/white/blue
Sounds like you are burning more fuel than air-running to rich
Nov 26, 2007 at 8:16 PM
GINARD67
[quote:035d48d19d="rasmataz"]Ho Ho Ho Merry Christmas
Sounds like you are burning more fuel than air-running to rich[/quote:035d48d19d]
Thanks for replay! The smoke is white but is dense. People are starting to give me looks when they drive past!
Yours Sincerely
Ginard67
Nov 27, 2007 at 8:08 PM
  • 75,988 POSTS
Pull over to a shop and have the following tests done-its an indication of a possible blown headgasket.
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Nov 28, 2007 at 9:56 AM
DIAMONDGOLDSILVER
Yes I can Help. If the block & the pressure tests ok then no problem.
Apr 4, 2008 at 5:48 AM
