2000 Other Alfa Romeo Models Repair after MOT
2000 ALFA ROMEO
107,000 MILES • 6 CYL • 2WD • MANUAL
MYLOVE
got alpha 2.5 v6, had it mot'd, needed top right arm replacing, steering rack, brake discs and pads. had it all done by alpha dealer, day later it starts knocking on the right side when turning the wheel left or right and when about to start driving from first gear into second, could feel the steering juddering, on a couple of occasions the steering wheel jumped out my hand and went the other way, when breaking heavey in traffic the car clonked really loadley. I took it back to the alpha dealer, now they are saying that the bottom right hand susupension needs changing because the brushes are perishing the suspension. I would like to know did they cause this problem to happen, as it was not knocking before they did their work on it? And if they did should have to pay them for having to repalce the bottom arm?
May 28, 2008 at 9:56 AM
DAVE H
  • 13,383 POSTS
they should have noticed this when they had it in to do the work ... and told you then that it needed doing .. the damaged wasn't caused by them .. the bushes have worn out over time .. but they should have noticed it ?? also the MOT inspector would have definately picked up on this fault and it would not have passed
Nov 11, 2008 at 2:04 AM
