1995 Other Alfa Romeo Models CO high emissions
1995 ALFA ROMEO
188,000 MILES • 4 CYL • 2WD • MANUAL
TIMON2006
Hi
I have an alfa romeo wich I changed the catalytic converter and the probe and the emission continue very high in the part wich
Should be 0.5 there is a number of 7 on idle or even when engine accelerated to 2500rpm or even more, always the same number.
Can you tell me what can be the problem is it from MAF or solenoid or another thing, please let me know so I can buy the part wich is needed to fix this.
Also when the car is cold at the morning when i start engine it runs at very low speeds and after a few seconds it acelerates to 1000rpm during a min and then go to the 850rpm wich is the normal on idle, so why does it when cold lows the rpm to +/-500 rpm.
Feb 17, 2009 at 9:34 AM
DAVE H
  • 13,383 POSTS
check clean or replace the MAF sensor !! also check and clean or rplace the IAT (intake air temp sensor)
Mar 18, 2009 at 7:52 AM
