Aldl connector or hand held scanner
80,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
MERCKENS DAN
I need to find a hand held scanner for the 1994, 1995 century. For these 2 years it has to be a hand held digital computer "scanner" that interfaces with the computer on board the car.do you know if they still make them? The aldl only has 3 wires going to it and 'b' is not one of them so you can not jump it with a paper clip.it is a 12 pin like the older model versions but it only uses 3 of them. Thanks and please don't send me to that site that tells you how to jump them! It wont work.
Sep 23, 2019 at 11:54 AM
Good morning.
The simple answer is no. There are no handheld scanners for this special ALDL. You need the full scan tool to access the data and codes.
The old snap on MT2500 did the job as well as other manufacturers.
Sep 23, 2019 at 11:39 PM
