Alarm off
120,000 MILES • 4 CYL • 2WD • MANUAL
LUPELOPEZ
I started the car ran great. Follow week it did not, I charge the battery and on alarm. Very thing works. Can I start it by push start without the alarm on?
Jul 6, 2018 at 6:15 AM
STEVE W.
  • 15,410 POSTS
If the alarm system has been tripped it will turn off the fuel system so even push starting will not work. It is most likely a result of the low battery that tripped it. You can try a reset and see if it turns off, that should be in the owners manual or you can try one of these:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jul 8, 2018 at 10:40 AM
