Alarm/keyless
150,000 MILES
NOT A CAR EXPERT
  • 17 POSTS
I have a sebring jxi convertible. I've been trying to get keyless fob to work sense I got it. It will not unlock or lock or open trunk. But if I hit the panic button it will trigger the alarm and unlock the vehicle. Then if I hit one of the unlock or lock buttons it will pause the alarm for a second or two. So I know all buttons work and is transmitting to the car. But why won't it lock it unlock. Would the dealer need to reprogram it or is it the keyless module or bcm bad. What are your thoughts
Apr 25, 2013 at 8:19 AM
get the dealer to re programm.
roy
Apr 25, 2013 at 8:27 AM
NOT A CAR EXPERT
  • 17 POSTS
Dealer reprogrammed it and said its the fob it's self. So 45 dollars for new fob on ebay. And 45 for programming it so I figured I'll just get a after market module instead. One with more features than factory. Would you be able to tell me where the factory module is so I can easy use those wires to hook up aftermarket one and also the wiring diagram for it to. For ease
Apr 26, 2013 at 2:14 PM
