Alarm keeps turning on?
151,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
CARSSUCK2TOWORKON
So I changed the master switch on my car because the windows weren’t working. Replaced it and the windows worked but the key stopped unlocking the car by itself. I didn’t mind it at all. After some time I changed the old radio with a new updated car play radio from Amazon. After 4 days of working, I got ready for work and started the car and the alarm went off. I disconnected the battery for the mean time.
Jun 3, 2025 at 8:02 AM
  • 55,691 POSTS
Great username btw. Can I ask if this has an aftermarket alarm on it? If so, this will be the problem. These go bad all the time, I would just remove it and reconnect the wiring back to stock which will help the electrical problems go away. If you are unsure, please post an image of the remote so I ca tell what's going on. If you don't have an aftermarket alarm, can I ask if the security light (red) is flashing when the alarm is going off?
Jun 5, 2025 at 5:21 AM
