Alarm enabled
137,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
SHAWNALFREY
  • 19 POSTS
Had a fuel line break, got that fixed. now the car will not start at all. tried every reset/relearn thing there is for this car. every time you turn the key the horn goes off no crank, just the horn. the alarm has drained the battery. is there something we are missing here? is the fuel line triggering the alarm system or something else?
Jan 29, 2019 at 10:00 PM
  • 55,684 POSTS
It sounds like the battery is weak causing a low voltage issue. Here is a guide to help test the battery to confirm the issue:
Jan 31, 2019 at 2:38 AM
