My car catches like it wants to start but immediately quits firing. The vehicle Anti-theth light is on.
It has done this at least 3 other times but eventually starts and runs for months before it would reoccurs.
What does the anti theth monitors. How can it be defeated?
SPONSORED LINKS
Tuesday, March 17th, 2009 AT 5:58 PM
RHALL77
MECHANIC
Sounds like you need a new pass lock sensor. It islocatd in the ignition switch. I wouldnt try to bypass it. But if you need to get it to a dealer, turn the key off for thirty seconds, try to crank it real quick and watch the security light blink. When it stops blinking (10-30 minutes) turn the key off and try to restart it. Then drive it to the dealer. If that doesnt work you will need to get it towed
SPONSORED LINKS
Wednesday, March 18th, 2009 AT 9:54 AM
BRANKO
MEMBER
Try disconnecting the battery (+). That should erase anti-theft and enable you to start the car. Happend in my "99 Olds and that's how I fix it
