Alarm remote control doesn’t do anything?
2,470,000 MILES • 2.4L • AUTOMATIC
JOHNNY GYMNOPOULOS
The alarm light on the dashboard works but the remote control flashing lights were activated. Nothing happens. The remote control has fresh batteries yet nothing is working.
Nov 6, 2026 at 11:55 PM
JOHNNY GYMNOPOULOS
The alarm light flashes on the dashboard yet the remote control doesn’t do anything. Northern lights blink what do you think? Is the problem? And please don’t say battery in remote.
Nov 7, 2026 at 9:17 AM (Merged)
MECHTRIX
  • 580 POSTS
Did you check the fuzes ? Theres a door lock fuze in the interior fuze panel on the drivers side near your left knee its a 25 amp fuze if its blown youl get no reaction from the remote also 8 believe there one for the integrated ecu/ security monitor / integrated modual same effect if the fuze is blown not sure what the size of that fuze is but im sure it somewhere between 10 and 25 but in this case id just check all of them for good measure of course you can do it quickly by using needle nose pliers makes it easy to pull check replace and go to the next one youl get through all of them fast ...tip have a good flashlight
Good luck hope this helps
Nov 7, 2026 at 3:25 PM
