Airmatic question
121,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
AWAL615
Okay, I have replaced two busted air struts myself. Now driver side Is up but not correctly driver front way high driver rear is probably in right spec. Passenger front is up more but a arm connection to steering knuckles bolt and stud is still touching rubber tire. And rear passenger is still up in wheel well. I know the level sensors have two in front and one on the rear torsion bar. Front sensors do have voltage as well as rear. The linkages on front look fine not broke or bent.
The rear linkage is still there looks like it could use another but it's still connected. My question is do I need to change or adjust height calibrations or is it more of a leveling valve block not functioning properly?
Nov 23, 2017 at 11:08 AM
KHLOW2008
  • 41,812 POSTS
Hi AWAL615,
After such work, you would need to re-calibrate the vehicle height and the job requires the correct scan tool.
Nov 23, 2017 at 6:14 PM
AWAL615
I was afraid that was the answer lol
I'm ordering star c4 now. It's just a must have if anybody is going to work on these mercedes
Nov 26, 2017 at 9:53 PM
AWAL615
Thank you for your help
Nov 26, 2017 at 9:54 PM
KHLOW2008
  • 41,812 POSTS
You are welcome, good luck.
Nov 28, 2017 at 4:32 PM
