Vent airflow?
206,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
NBM1961
  • 11 POSTS
when heater or a/c is on air comes from defrost and floor but not out of dash.
Jun 11, 2024 at 3:14 AM
  • 55,673 POSTS
Yep, this happens when the small vacuum line going into the firewall from under the hood is broken or disconnected from the engine, I would raise the hood to inspect this small plastic hose. please go over this guide to see what I am talking about:
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Check out the images (below). Please upload pictures or videos in your response to any problems so we can see what to help you with. Here are the vacuum lines under the dash which can sometimes be broken as well.
Jun 11, 2024 at 4:20 AM
NBM1961
  • 11 POSTS
found the problem, plastic piece on top of the door that connects to the acuator was broken. with a piece of metal i opened the door to the vents and secured it. Defrost not needed in AZ.
Jun 16, 2024 at 8:01 AM
  • 55,673 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Jun 17, 2024 at 4:07 AM
NBM1961
  • 11 POSTS
hi Ken,
I have another problem. i disconnected these wires without marking them and know i don't know where they connect. it's a red, yellow and a black wire that go to the three inline connectors shown (pictures). can you help please?
Jun 17, 2024 at 6:39 AM
  • 55,673 POSTS
Sure, I can help but we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Jun 18, 2024 at 3:35 AM
