Air conditioner not working properly
131,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
778MORE
A/C compressor does not disengage. The cooling fan under the hood does not come on. When you turn on the A/C blower inside the car the A/C light goes out when you select the number two speed.
Jun 15, 2018 at 4:50 AM
KHLOW2008
  • 41,812 POSTS
Hope you have got it correct, compressor remains on without disengaging. If that is the case, it most probably is a faulty relay somewhere.
Does blower motor works at all the speed ranges?
Jun 16, 2018 at 3:34 PM
778MORE
Blower motor works in all speeds but, the A/C light goes off in the number two fan speed. The fan switch is attached to a board with the vent selector and temperature switch. The fan switch appears to be broken off the board but the fan speed works in all speeds.
Before you were able to respond to me I added some Freon to the A/C and it started working.(both the A/C and clutch) When it did it start working it started to sling out oil or what appeared to be oil from around the compressor. I am assuming it may be a faulty compressor. I hope I am assuming correctly.
Jun 18, 2018 at 2:04 AM
MIKE H R
  • 3,094 POSTS
The system needs some oil in it for it to work right. With it putting out oil there may be too much oil in the system and blown a seal. Check to see if it is coming from the compressor or somewhere else. Check the hoses.
Jun 18, 2018 at 11:23 PM
778MORE
The A/C was working fine until ten days or so. When it quit working I had a friend put gauges on it and it did not any Freon in it; We added Freon and it worked for five minutes or so until the Freon leaked out. The bearing starting to make noise now.
Jun 19, 2018 at 12:34 AM
MIKE H R
  • 3,094 POSTS
You have a leak in the system. If the A/C compressor stays on I would disconnect the wire wires going to the compressor. That way it will not do any damage to the system. With it leaking Freon and the compressor staying on it could do some damage to the system.
Jun 19, 2018 at 12:42 AM
778MORE
Jun 19, 2018 at 9:46 PM
  • 55,604 POSTS
Here is a guide to help you see what you are in for when changing the compressor out:
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Cheers, Ken
Jun 22, 2018 at 5:19 AM
