A/C compressor locked up
138,000 MILES
DEBORAH RUSHING
Air conditioning compressor has locked up. It will not crank is there anyway to bypass it?
Dec 9, 2018 at 11:00 AM
HARRY P
  • 2,292 POSTS
Hello and thanks for using 2carpros. I am attaching three images below. Each is a different drive belt routing, dependent on exactly which engine you have. I cannot know which engine you have without the eighth digit of your VIN number. In figures 1 and 3, you would have to buy a bypass pulley and belt and would be able to do it. In figure 2, it is just a matter of buying a shorter belt and installing it. The parts (if available) should all be available at your local auto parts stores. As far as I can tell, a bypass pulley is available for VIN 1 (3.8L supercharged), but not for VIN K (regular 3.8L Naturally Aspirated). VIN L just needs a shorter belt, which the parts shops can get for you (just ask them for a belt for a 1995 Oldsmobile 98 without A/C).
Here is a general guide on how to install a belt: https://www.2carpros.com/articles/replace-serpentine-belt
GM's instructions on how to replace the belt are in the fourth image. They are not very helpful.
Go ahead and get that VIN number and post it here and I will dig around and see if I can find more useful information on how to change the belt.
Dec 9, 2018 at 11:46 AM
DEBORAH RUSHING
The 8 letter is a k.
Dec 9, 2018 at 11:38 PM
HARRY P
  • 2,292 POSTS
I am sorry but I just do not see where anyone makes a bypass pulley for that engine. I am kind of surprised, to be honest. This engine is used in probably a dozen different GM cars in the early and mid 1990's and there is probably still a half million of them roaming the streets. Okay maybe not that many, but you get my point. The next thing to do would be to find a used A/C compressor, maybe from the local salvage yard or on eBay, and have someone install it. If you like having a warranty on your stuff, then new compressors are available too. It is not a terribly difficult job, but will require discharging and recharging the system with Creon if you want the A/C to actually work.
Dec 10, 2018 at 4:47 AM
DEBORAH RUSHING
Yes, that is what I thought. Thank you so much for your help.
Dec 10, 2018 at 5:19 AM
HARRY P
  • 2,292 POSTS
No problem. Please come back any time and send your friends too.
Dec 10, 2018 at 6:59 AM
