AIrbags and Seat Belt Tensioners?
160,000 MILES
DAVIDMABELLE
  • 8 POSTS
My partner converted her car into a campervan and now has the airbag light on and the seat belt tensioner light on. She bought an OBDEleven to see if she could turn off the rear seat. It is asking for a security access code. Need to know if the Airbag Control Module allows this for this year make and model.
Feb 23, 2025 at 12:18 AM
  • 55,694 POSTS
The system and the sensors must be connected for the system to turn on. Where airbags and seat belts removed? You will need to have someone reprogram the systems for you which can be done with the correct scan tool/programmer.
Feb 23, 2025 at 3:19 AM
DAVIDMABELLE
  • 8 POSTS
I have an obdeleven however it seems I need security code to do modifications. Where can I find the security code for 2016 VW Maxi Caddy?
Feb 23, 2025 at 4:05 AM
  • 55,694 POSTS
You will need to call the dealer with the VIN number, and they may ask more questions before they give you the code.
Feb 24, 2025 at 2:48 AM
DAVIDMABELLE
  • 8 POSTS
Are they required to give you the code? What kind of questions?
Feb 24, 2025 at 3:08 AM
  • 55,694 POSTS
They will probably need to code it for you. They just want to know that you are the owner of the car. Either way I way give them a call.
Feb 24, 2025 at 3:47 AM
DAVIDMABELLE
  • 8 POSTS
The official VW mechanics unfortunately will not help. It is for the airbag system, and they are worried about liability.
Feb 24, 2025 at 6:59 PM
  • 55,694 POSTS
Yep, that will be the problem. Can you reconnect the items that were removed and just tuck them out of the way?
Feb 25, 2025 at 1:50 AM
DAVIDMABELLE
  • 8 POSTS
Unfortunately no longer have them. Only solution now is to use dummys 3.3 ohm resisters from eBay and then reset with OBDEleven
Feb 25, 2025 at 3:01 AM
  • 55,694 POSTS
Sounds good, where did you get the info of 3.3 ohm resistors?
Feb 26, 2025 at 12:32 AM
DAVIDMABELLE
  • 8 POSTS
Several YouTube videos. https://www.youtube.com/watch?v=xOZHUFlwFGE There are also dummys made with the pins that make it even easier on Ebay. Different videos show the range to test is between 2.2-3.3 ohms.
Feb 26, 2025 at 5:17 PM
  • 55,694 POSTS
You can give it a try (i would not) but this video is on a Chevy Traverse, also you have a change of setting off the airbags system, FYI.
Feb 27, 2025 at 3:09 AM
DAVIDMABELLE
  • 8 POSTS
I understand.. I had a different video. But I could not find it. Sold the car to a mechanic who is going to get it working. Thanks for everything!
Feb 27, 2025 at 3:18 AM
  • 55,694 POSTS
You are welcome, please use 2CarPros anytime we are here to help.
Feb 28, 2025 at 12:43 AM
