In order to replace turn signal switch, I had to remove the steering wheel which necessitated removing the airbag. However, after the reassemble, I see an airbag warning light. I took the steering wheel off again to check for problems. None found. I cleaned the metal contact circle. Reassembled again, same problem. Any ideas? Tom
Sep 7, 2019 at 9:19 AM
