Airbag module
10,000 MILES • 2.2L • 4 CYL • 4WD • AUTOMATIC
SER3NIK
  • 6 POSTS
Hello. Can you tell me, please, if the airbag module for this vehicle crash error can be repaired on the car using the tester or it has to be disassembled from the car and rewritten?
Dec 20, 2018 at 6:42 PM
Good afternoon,
The module has to be removed, sent out and reset. there is no way to reset it on the car.
in most cases, the module is replaced with a new one. that can be programmed on the car with factory software.
Dec 23, 2018 at 5:07 AM
Did you respond? I got an email but nothing came through.
Dec 3, 2021 at 4:35 AM
