I have a 1999 Ford Explorer and am having trouble passing inspection due to a recurring air bag light on the dash. I've read up on it and the best information I can offer is that it is blinking 3 times, then 6 times after starting the vehicle. This continues until I shut the truck off. I had someone hook an OBD2 up to it and they said that the airbag system is not registering at all through the diagnostic tool. So, after more research, I find that there is a connector underneath the driver's seat that may have something to do with my problem. There are two wires for the connector but only one is plugged into it, the other has been broken. So, instead of splicing the wires back, the broken one was way too short to splice, I had someone solder them back together. The light still came on. I returned to the OBD2 and it is still not registering an airbag system. What should I do? I've troubleshot all I can with the knowledge that I've obtained.
Apr 15, 2013 at 12:05 PM
