Airbag light reset
99,500 MILES
RSEIFERT71
after servicing the driver side seat heater has an active airbag condition and I cannot figure out how to reset it. Ideas are welcome. It's also not the steering wheel clock spring, fyi.
Mar 25, 2021 at 11:33 PM
  • 31,937 POSTS
You will have to run a diagnostic code check to see what has activated the check light, if a seat pressure sensor was unplugged and the ignition was cycled it will set a fault code, it may just be a simple code clear is all that is required. This will require a scanner with re set and code clear capability.Try this and let me know if you still have a problem.
Mark, (mhpautos)
Mar 26, 2021 at 9:41 PM
RSEIFERT71
Thanks Mark, I’ll give that a shot this afternoon and let you know. Thanks for your time. Just wasn’t sure if I would be able to reset without a scanner.
Mar 26, 2021 at 9:58 PM
  • 110,248 POSTS
I noticed that we haven't heard from you for a couple of days. Has any progress been made? We are interested in knowing.
Let me know,
Mar 29, 2021 at 12:37 PM
RSEIFERT71
Oh, I thought that I replied. Yes, the airbag light is reset. Thanks!
Mar 29, 2021 at 7:17 PM
  • 110,248 POSTS
Thanks for letting us know. Your response will likely help others.
Please feel free to come back any time in the future. You are always welcome.
Mar 30, 2021 at 10:53 AM
