Airbag impact sensors
1999 TOYOTA CAMRY SOLARA
108,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
ROB1FLO1
Driver and passenger airbags deployed in an accident, I purchased the airbags to install them my self and I will like to know if the two impact sensors in front of the car need to be replaced as well? I have removed them from the car and they looked in pretty good shape, no corrosion at all and the reading with the Ohm meter shows 822 at the connector pins. Please advise and thanks in advance.
May 1, 2017 at 10:20 AM
STEVE W.
  • 15,345 POSTS
Sensors get replaced and the SRS module needs to be checked and deploy codes erased. For that you need a scan tool.
May 1, 2017 at 10:24 AM
ROB1FLO1
Thank you Steve, very quick response.
May 1, 2017 at 10:53 AM
STEVE W.
  • 15,345 POSTS
Be careful and do not plug in the bags until you make sure that the rest of the system is okay. Watched a guy plug a steering bag in one time when the SRS module had a charge and was shorted. Not pretty.
May 1, 2017 at 5:23 PM
