Airbag codes
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
DIVIDES
  • 903 POSTS
Attached
Dec 9, 2021 at 11:31 PM
More than likely these are all related however, I am attaching the testing for the first and last DTC because they could be separate issues.
However, I would suggest starting with the first code and work through it and if the others are still there then we can address them after.
I suspect that they are all related so let's fix the first and go from there.
Let me know what questions you have as you work through it.
Dec 11, 2021 at 8:46 AM
