car will not start after airbag deployed
2010 BMW 328
93,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
JORDAN814
Airbag deployed car will not start. Minor front end damage.
Feb 14, 2018 at 5:14 AM
WRENCHTECH
  • 20,761 POSTS
I believe there is a special fuse right at the battery that automatically blows upon airbag deployment. You have to get it from the dealer.
There are numerous things that have to be replaced after a deployment, including the airbag module and it is possible that could disable starting also.
Feb 14, 2018 at 7:14 AM
JIS001
  • 3,412 POSTS
Just wanted to add, during a bag deployment the SRS module sends a signal to the engine control module to shut the fuel pump off to avoid a risk of fire. After repairs are done, the system needs to be reset using a factory or similar type of scan tool to give the okay to start
Feb 14, 2018 at 2:04 PM
WRENCHTECH
  • 20,761 POSTS
The airbag module cannot be reset after a deployment. It has to be replaced.
Feb 14, 2018 at 6:08 PM
