air suspension issue hear the compressor running?
170,000 MILES • V8 • 2WD • AUTOMATIC
BHAMDOC1
  • 427 POSTS
When it sits overnight the rear sinks, more on the driver side. Once you start the car it will start rising to a close to 100% level. I could hear the compressor running, and some hissing from rear driver side, then after a while all stops and its leveled. Then when I turn it off you could slowly see the driver rear sinking and a hiss. Do you know what usually goes wrong with these?
Jan 9, 2026 at 1:53 AM
  • 55,837 POSTS
The hiss is the clue, the system leaking, you need to find the source of the noise which is probably the level ride shocks. You can use a bottle of soapy water to help you, spray it near the noise and look for bubbles to confirm the source. Please upload an image or a short video in your response, so I can see what's going on.
Jan 10, 2026 at 1:35 AM
