Air suspension conversion
180,000 MILES
GARYGARLAND1371
Why will the Suncore 53F-30-HD Air Suspension Conversion Kit not work on a rear wheel drive 2001 Expedition-VIN 1FMEU15L31LB82811, but only on the 4WD version?
The reviews for the 2WD conversion kits is always negative with the expedition sagging afterwards. Will the mentioned kit be able to be used on the 2WD to give it more lift, etc?
Apr 22, 2019 at 9:46 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
One thing I have done in the past was when the rear bags were damaged is you can go to the Ford dealer or a wrecking yard and get a metal coil spring replacement to eliminate the airbags all together.then you can use metal coil spring and a decent shock.Ford is about $250.00.You can then remove fuse from the compressor. Not sure if that is what you're trying to do.Hope this helps and thanks for using 2CarPros.
Danny-
Apr 23, 2019 at 3:51 AM
