Recommendation needed as to where to purchase Air Shocks?
40,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
LUIS MIGUEL APARICIO
Hi, the air shocks are bad, where do you recommend buying it from?
May 13, 2024 at 3:24 AM
STEVE W.
  • 15,411 POSTS
I generally opt for the OE parts where possible, if you want aftermarket parts SKP and Westar both sell the replacement air springs for the front and rear units. There are also conversion kits that replace the OE parts with aftermarket struts and springs to remove the failure prone OE parts.
May 13, 2024 at 8:10 AM
