ll of a sudden the battery light comes on then I shut the car off
192,000 MILES • V8 • 2WD • AUTOMATIC
DAWNK804
So I take my absolutely well maintained Lincoln. Fyi, only went over the oil change one time. All interstate miles. Everything perfect in that car until one day the air suspension goes out. Not shocking lol. Anyhow I get it back from the shop now it's acting like the alternator or serpentine belt or computer system is fried. It was absolutely fine the day I took it in. I get it out of the shop and all of a sudden the battery light comes on then I shut the car off go in the house. Next evening I head to work. No light. Okay fine. Well I get off work which is right before sun up and the headlights seem a little dim but still no battery light. Then I get to house go to sleep I just wake up head to grocery store before this hurricane. Heading home my lights go off my ABS goes out my power steering goes out and everything including my headlights start flashing. Nothing in my computerized dash is working. Engine still running thank God I only had about 2 blocks left to go home. I get home can't roll up my windows. Shut the car off try to turn back on battery just clicks. Let it sit for about 10 minutes I turn it back over the headlights start flashing but I have enough juice to roll up windows. Headlights still flashing on and off and on and off I open my back door to get the groceries they shut off.
Sep 2, 2019 at 12:03 PM
BMDOUBLE
  • 1,139 POSTS
There's a good possibility that your alternator has failed. Low voltage will cause the modules in your car to start shutting down and will turn on various warning lamps. Here is guide for testing the charging system:
if okay This sounds like the starter is having problems or the battery needs to be load tested these guides can help us fix it.
and
Sep 2, 2019 at 12:38 PM
DAWNK804
I get that. I figured it was the starter again! all set thanks for the help.
Sep 3, 2019 at 9:58 PM
BMDOUBLE
  • 1,139 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Sep 4, 2019 at 12:55 AM
