Air Ride or auto leveler?
213 MILES
BGUY
My SUV's compressor by driver side back tire sometime turns on when driving which seems to make the truck lose power when accelerating. can I pull the fuse under hood and still drive safe?
Mar 5, 2022 at 8:26 AM
  • 110,248 POSTS
The air ride system really should be operating at all times. I wouldn't suggest removing the fuse.
However, when the compressor turns on, it really shouldn't cause a power loss. By chance, have you had the computer scanned for codes, specifically the can-bus? CAN stands for controller area network. Basically, all the different modules are tied together via a few wires. If there is a diagnostic code related to this, it should indicate it.
Here is a link explaining how it is done:
If relevant codes are stored, they should start with the letter C. For example, a C0711 is a code specific to automatic level control. If possible, I recommend scanning the can-bus to see if something is stored. It may point you in the direction of the problem.
Let me know what is happening so I can better help you. For example, does one of the sides lose air?
I will watch for your reply.
Mar 5, 2022 at 2:32 PM
