Air ride leak
198,000 MILES • V8 • 2WD • AUTOMATIC
GARY SHARP SR.
On the drivers side rear where the air ride bag sits there is a leak at the bottom right where it sits on that bracket. is there a gasket or some kind of seal?
Mar 23, 2019 at 7:08 AM
JIS001
  • 3,412 POSTS
Hi, and thank you for using 2CarPros. There is no gasket for that. If the bag is leaking then you would need to replace the bag. The bags are usually expensive and there are conversion kits you can buy that would allow for the bag to be removed and install a coil instead. Here is a link to see the part and an estimate on parts:
https://www.carid.com/arnott/rear-coil-spring-conversion-kit-mpn-c-2180.html?singleid=10116104&url=91552632
Let us know if the information was useful.
Mar 26, 2019 at 4:16 PM
