Where is the Air pockets bleed valve located?
150,000 MILES • 2.5L • 4 CYL • AUTOMATIC
KIMBERLYDAWN
Where is the bleed valve located for the coolant to remove air?
Dec 15, 2024 at 6:43 AM
KIMBERLYDAWN
I do not see the answer.
Dec 15, 2024 at 11:57 AM
STEVE W.
  • 15,410 POSTS
Sorry, there seems to be a glitch in the matrix. Your car doesn't have a bleeder valve. Instead, you start with a cold engine, top the coolant up as far as possible, now start the engine and while it's running add more coolant. Put the cap back on and let the engine run until it's warm. Shut it off and let it cool, add more coolant and repeat the process until the coolant stays filled.
Dec 15, 2024 at 11:49 PM
