Settings on the knob are the usual face/floor/defrost and max A/C. if actuator is the problem i need to know the location of the actuator.
Feb 27, 2025 at 7:57 PM
✓Experienced Mechanic
It sounds like the mode door actuator isn't working or something has come apart. The actuator is located under the dash on the driver's side of the HVAC box.
If you look below, I attached a pic showing its location. The remaining pictures are the directions for replacing it.
I hope this helps. Let us know if you have additional questions.
